Need Help Programming Starcom21 on BCD996P2
techgeek01
Highland, IL
I am trying to program Starcom21 talk groups in southern IL ISP district 11. I am new to programming trunking systems. I tried to do the import from Radio Reference but I am not picking up anything on my STARCOM21Statewi site. I am programming with Freescan. I attached some screenshots of my programming. Any help is appreciated.
teufler
ST PETERS, MISSOURI
just by chance, in Freescan, read the radio, then do a ctrl k. you will see you system assigned keys. do auto assign. save and send to the scanner.possible because you are not hearing, Ill is not assigned to a system key.Also change from system type motorola type 2,p25 to p25 digital. save and send to the scanner.
TGP
Metro East, IL. St. Clair County
Being that this is Starcom21, I'm sure tons of those departments are encrypted.
Few, but as many as you think. Very few actually,
Here in S.Central/Southern IL.
Especially Madison/St Clair County. Very different up North
If he's only wanting ISP D 11 He needs to remove or Avoid the other Departments as
Not to overwhelm the scanner.
Tom
MikeyC
Utica, IL
You have Starcom entered as a "Motorola Type 2" system - it should be entered as a "P25 Standard (XT)" system
techgeek01
Highland, IL
Thanks for all the help. I was able to get the channels working now. The problem was because I had too many talk groups in a system. When I broke it down it worked fine. Now the only department I am having trouble picking up is Highland. Radio Reference does list it as encrypted. Is there anyway of getting around that and being able to decrypt the channel? I attached a screenshot of the Radio Reference page of the channel I am trying to listen to.
