I just bought bcd396xt and downloaded freescan, but my computer wont reconize the scanner. any help would be appreciated. been reading the forums, but im not understanding how to get the usb to read a com device
If your PC has a serial (COM) port, then you can use the
serial cable that came with the 396XT (if you received that with the scanner).
If your PC does
not have a serial port (most laptops & many newer desktops do not), then you may need the
USB-1 cable, with the proper drivers installed.
If you have the original type COM cable, but no COM port on your PC, you may be able to use a USB to Serial adapter.
See this page:
Connecting scanners via USB - The RadioReference Wiki
Once you have a working cable connected to your PC, then use the Auto function in FreeSCAN to locate the available COM port. (Links [rovided above for the cabl;es are from ScannerMaster, but the same items are available from a number of online sellers.)
