need help setting up my baofeng uv-5ra
wlorch1
xenia,ohio
trying to get on a REPEATER with a input frequency of 467.700 and the output frequency of 462.700 it is an open system this is it
EMPIREWIRELESS700 SHERBURNE, New York
Network: [None]
Type: Open System
Updated: May 07, 2012
Owner: EMPIRE
Travel Tone: No
ORI: Yes
Apprx. Range: 72.3 Miles
Output: 462.700 MHz CSQ/No Tone
Input: 467.700 MHz CSQ/No Tone
i have a baofeng uv-5ra radio and need help setting up the radio to use on the REPEATER
i don`t know anything about travel tones or what ORI is can anyone help me out i have my gmrs lic.
wqnn824
thank you
william lorch
awasser1
Apache Jct, AZ
download chirp software...thats what I use. never programmed it manually. theres a spot for the offset or i just put in both frequencies tx and receive. after you dl the software u will see what I mean.
wlorch1
xenia,ohio
thank you
where can i get the download from and is it free
mirayge
Decatur, IL but my heart is from Bugtussle
There are two ways to manually program a repeater in to the uv-5r. The easiest way is to switch to vfo mode with the orange button. Use the top A line. You could use either one probably, but both are set independently. Run through the settings to make sure everything is the way you want it such as frequency step, busy channel lock out, wide band, transmit power, etc. Since they have no tone on that repeater make sure the receive tone especially is turned off. Now put in the RECEIVE frequency and save it to a memory channel. After that is done you can put in the TRANSMIT frequency and hit the scan button quickly. An R should appear in the display indicating reverse. Now save that to the SAME memory channel. After you turn the radio off and go back to channel mode there should be a +/- symbol on that frequency. Quickly pressing scan again will show you the transmit to check if it is set properly.
