Goldeagle222
- Joined
- Apr 22, 2017
- Messages
- 14
Only difference is it will spike up to full bars but still says finding control channel. But i have yet to hear anything when comparing to an scanner app.
That's with the last file?Only difference is it will spike up to full bars but still says finding control channel. But i have yet to hear anything when comparing to an scanner app.
OK.Yes sir. I have just been overwriting each time you send a new one.
I'm wondering if the Mecklenburg site is similar to a couple in my area.I can say the Stanley Simulcast doesn't even show a signal or anything just shows control channel, but I will try driving into Charlotte. I tried the Hold option and I heard nothing and saw the same so if I get readings while in Charlotte then it's just my antenna I guess. I don't live that far from Uptown Charlotte so I don't know how I wouldn't be able to hear the chatter. So maybe all of this is wrong data on the site frequencies. Whats the best way to check and i will do it.
By "overload", I am referring to the scanner being overwhelmed by signals from other sources, whether that is from multiple cell towers, or a strong and/or close transmitter from another system.What do you mean by overload? Do you mean I'd heard radio traffic in Cabarrus while trying to listen to Charlotte? I guess all that's left to do is drive into Charlotte. I will let you know what my results are. Thanks for your help.
Sent from my VS985 4G using Tapatalk
I bet the "finding control channel" is probably because of the Stanly site. As you mentioned that when stepping through the frequencies as I suggested before that you got no sign of a signal on that site, I'd suggest that you simply either delete it, or lock it out. Since you said that you were receiving Charlotte area activity when closer to that county, the scanner obviously had found that control channel. And, as Caburrus is working, that channel is also "found". The only other site in the file is the Concord site for Viper, which I doubt is a problem to receive. The "still broken up" on Charlotte activity could be a distortion from the simulcast site being used. The farther away you are (if the antenna change brings it into range at home) the less you have to deal with distortion.So after a small drive into Charlotte I found I got full bars and could hear the traffic much clearer (still kinda broken up) but it would still say finding control channel. So I think my best option is to buy the 800MHz which is fine because it's only 20$ on Amazon. Would there be any way to lessen the signal on Cabarrus if it got overloaded. I doubt there would be but I figured i'd ask.
When it goes into one of the Special Search routines, press Function plus the L/O (lockout key) to lock out permanently.I need help! I turned on the Special search on my BCD325p2 not knowing how I did it. Now I cannot turn it off. I've looked in the manual and cannot find.Hope someone can help me.
