Need help with a Mute circuit
AZ_chris
Glendale, AZ
I have a muting circuit unit I purchased, but I have run into a problem I did not anticipate (nor could have).
The muting wire from the stereo puts out a constant 12V, and I was expecting no voltage. This wire needs to be grounded to trigger the stereo to mute.
The muting unit does not latch to ground until transmission is detected, so the voltage is backfeeding into the muting unit.
Does anyone have a solution for this?
jackj
NW Ohio
Your muting circuit needs a trigger, that's why it has 12 volts on the sense lead. Grounding the wire tells the circuit to mute. The action could be triggered by either the application of a voltage or a ground, your circuit uses a ground. You could build a circuit that would invert the signal but some type of signal is necessary.
