Scan speed
I am in the process of modifying one of my scanners to make it scan faster. Now the mod calls for a
"quartz microprocessor crystal" of a higher value.
It sounds like this MOD is changing the speed of the CPU in your scanner in order to change the scan rate. BAD IDEA for quite a large number of reasons.
I will assume that you want to make your scanner scan faster; as I can't imagine many folks going through too much to make it go slower. Generally speaking when circuits run faster, they will consume more power. Additionally they will generate more heat. But those are "minor" issues.
One consideration would be whether or not the CPU and supporting circuitry CAN run faster than it currently does. Oh sure it might do that when you first make this MOD, but what happens when batteries get weak or you are in a hold or colder environment than usual? Or when the components age (more)?
Next, just making the scanning faster does not make it work. It actually takes a measurable amount of time for the radio signal you are receiving to get from the antenna connection to a point detected by the CPU. Change channels/frequencies and there is another measurement.
Years ago I added CPUs to my PRO-10 and PRO-77 scanners and wrote custom firmware to do the scanning. I was quite surprised at how long I had to wait on a channel to detect a signal, even if the signal was present before I got there. For the hardware I was using (crystal controlled remember) it was around 125ms. I could have easily made the scan speed 100ms or 1/2 of what I coded, but the bottom line is it did not work. I needed every bit of that 125ms (8 channels per second) so I did not miss signals.
Bottom line here, if you want a "faster scanner", purchase one that is designed with the scan speed you need. Many of those MODs out there are good at selling books, but don't provide a lot of real value.
