Need help with Augusta/Richmond Co. Trucking!
Jacob
Grovetown, Ga
I have a BC780 HLT. I have checked and doubled checked the freqs and talkgroups that are listed on the site (yes) the new talkgroups. I have entered them in the scanner and checked. Type 11, Plan 1. When I return to scan mode I press Truck and when the scanner locks unto a signal, I see the freqs but no M to the right and no ID that I have programed in at the bottom. Anyone have any what could be happening? Thanks Jacob WD4EHW
BANDIT
Gainesville, Ga
If you have it set for trunking don't press trunk, just hit the scan key for ID scan or the Search key for ID search. If you hit the trunk the scanner will lock on the control channel and you will see all ids that are active pass by on the display but thats all, it will not trunk the system Just sit on the control channel. Just make sure you have the bank set for trunk and each frequency set for trunk, select that bank and hit the scan key, do not push trunk. :)
