n8nqu said:
i want to do a master reset and start from begining.thank you.Bill
If you mean clear the memory (erase all channels), then:
Turn the scanner off.
Then, while holding down the number "2" & "9" keys, plus the "Manual" key, turn the scanner on.
The same sequence works on most all Uniden scanners (for those that do not have a "Manual" key, use the "Hold" key).
