opticalserenity
I just added it, nothing.
Have you tried any conventional frequencies to see if they work? Have you tried receiving one of the WX channels? Has the radio worked before this? Is it new? If so, and it's in the thirty day return window, take it back and get another one. Don't know what else it could be.
Larry
It works fine on the Fulton system, Marta, and plenty of conventional frequencies (including WX).
It's odd, it's almost like it's just deaf to cobb. Even when it does decode anything (on 857.2125 is where I picked up the data) it's very low signal strength (usually around 30%).
I noticed in your first post you have ARC500, give it a try.
Is your "30%" coming from the TSYS Analyze display? If so, that's not signal strength - it's the control channel decode success rate (i.e. the scanner is successfully decoding 30% of the control channel messages that it's expecting).
30% is awfully low.
EDIT: and 30% would probably keep the scanner from locking onto the control channel.
If he's having problems when using software from the guy who wrote the scanner's firmware, it seems unlikely that any other software would solve those problems.
In one of the files I posted and the one that is programed in my Pro106 which receives Cobb there is only 4 frequencies and 857.2125 is the control channel. In the videos it shows two CC's
