Need help with display interpretation on BCD536HP
daddyjohn
I was in the search mode and ran across this DMR system. I believe that DT3 means that it is a type 3 system? Color Code 2 is self explanatory as well as Slot 2 and TG. But what does Nt, S and U specifically stand for? I couldn't come up with anything in the factory manual or the "Easier to Read Manual". Any help would be appreciated. Thank you.
Ubbe
Stockholm, Sweden
Each system can be set to a Network id between 0-15 (that the system sends out but are often refered to as being 1-16) and that 12 are the default value that Hytera seems to use and the system admnistrator doesn't bother to change it as it is not used for anything, but all radio equipment needs to use the same network id. I have several systems that use Network 12 as Hytera basestations are used at about 80% of the different systems here.
/Ubbe
