does any one know if there is new frequencies for the area of albermarle county virginia such as crozet?
Use the Radioreference Database. You'll see that in order to receive everything, you will need a digital scanner. You mentioned iScan, but that's too vague to determine what scanner you have. If you have a digital one, then you're set. Doesn't it have software that you can import the RRDB?does any one know if there is new frequencies for the area of albermarle county virginia such as crozet?
Might also want to read up on trunked systems. Frequencies are used for control channels and voice channels. You don't program trunked systems the same as conventional. You monitor (for the most part) talkgroups.hey thanx for info I do have digital one iscan 107 but some of the frequencies are not working so how do i retrieve the new frequencies. If that is possible at all. thanx mike
