Need help with Ocean County System on BCT15
fireman_dude
Barnegat, NJ
I have just programmed my BCT 15 using the registered version of the software. The problem I am having is I can only Receive the Ocean County Trunk System in the ID Search Mode. It will not receive in the ID Scan mode. I have all the Tags programmed properly, the freqs are all correct and my settings are as follows.
Status Bit - Enabled
End Code - disabled
Modulation- Auto
Attenuator- disabled
Band Plan
Base 505.0000
Step 12.5 Khz
Offset 380
Seems to me everything is okay. Any ideas ?
fireman_dude
Barnegat, NJ
Yeah, Okay. My big screw up. Never put a zero before the ID even if it appears in the database you got it from. Apparently BCT 15 cancels out the ID if the first digit is a zero. I'm an ass, what can I tell you. At least it's working now.
DJ88
Brick Twp., New Jersey
Nah, you're not an ass. We all screw up once in a while. If we didn't we wouldn't be human. At least you found the mistake and got it working, and that's all that really matters.
