bikerg2001
- Joined
- Aug 30, 2004
- Messages
- 37
i just heard 2407 on marshall cty freqs...
Wow Mike you just opened a whole new world for me with that tip for Mylan will have to try it out.i got my receive problems fixed from my earlier post i forgot to plug my antenna back into the multicoupler this morning boy do i feel like a big dummy.anyway will continue to monitor as time permits.Adam
Mylan,
In Pro96Com, go to Edit / Decode Configuration / Screen Settings.
Except for Dump / Raw Dump, anywhere you have the option to "make this screen visible" and to "turn on autosave at startup" you probably should. It may give you access to a few more screens you don't usually see, and it will help to ensure that your data gets saved to files often.
If you a cool guy at all, you'd email me your *.txt and *.csv files in the System 170 folder of Pro96Com and let me take a look at emYou could zip em up first. or send em on MSN.
Mike
ROFL, yeah plugging the antenna in definitely helpsI didn't realize you were running Pro96Com. Good deal, glad the suggestion helped. Given how little I can monitor of P25 systems, I try to eek out every bit of info I can.
Mike
Due to 9997 being a med talkgroup, if I follow the way other admins have added these in the past I would end up adding it to the Regional EMS - Medcom section instead of to Ohio Co. Personally I feel it is better served if listed in Ohio Co. I'm torn on what to do with that one.
2145? Once you can confirm it's the DTF I'll add it! (ok, just joking, knowing you can't confirm it rofl)
Turn on your MSN!
Mike
Mylan,
Mike
Mike why does your state of Ohio System have some of it's TGID's doubled? Look at the counties and ... well lets go with the Mutual Aid, EMA, and Hospital / Ohio Dept. of Health TGID's. They are all almost doubled. Today they are all listed in a Group called Temporary Talkgroups.This has just started happening within the past day or two. Looks like one of your Admin brothers is undermining your thoughts here! What's up? Maybe they should be listed in both TG's. or just do away with the main TG and put everything into the county TG instead.
A "System 170" folder would exist inside the folder where your Pro96Com is installed. If your Pro96Com is installed in C:\Pro96Com, then you have a folder called C:\Pro96Com\System 170 .yeah no crap .... problem is i looked for the system 170 folder and i cant find it..... where am i supposed to find this system 170 folder...... i cant anywhere... on pro 96 com
BTW... Where can I find Mike's State of Ohio system?.... Is that the MARCS system or is there another one I am missing?
Mike, I was looking at my logs and I see no hits on 2127 at all.... Because I heard Stone Church Fire coming across on TG 2129 yesterday, I think you should go ahead and make that change in the DB unless we get additional data to disprove that
