need help with old Motorola repeater
ffemt6488
troy mo
Hello i have a old motorola crystal type repeater Transmitter #CC3049 it transmits ,recieves,and repeats however the transmit audio is almost so low its hard to hear it. Ihave yet to find any imformation let alone manuals , help would be much appreciated. This unit will not be used in the states is actually going to another country as a donation im just trying to get it up and running .
ffemt6488
troy mo
repeater
Ok can do i will take some pictures tonite i will also get the full ID. number
ffemt6488
troy mo
repeater
motrac thats the most imformation ive gotten since ive aquired the thing and yes vhf
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Hello i have a old motorola crystal type repeater Transmitter #CC3049 it transmits ,recieves,and repeats however the transmit audio is almost so low its hard to hear it. I have yet to find any information let alone manuals , help would be much appreciated. This unit will not be used in the states is actually going to another country as a donation im just trying to get it up and running .
Two places you should always look when seeking info on older Motorola radios: batlabs.com and repeater-builder.com
http://www.repeater-builder.com/motorola/manuals/c74msy-community-rptr-man-6881056a35-c.pdf
(In this case, the motrac is too old for batlabs.)
Now that you know it's a motrac, search here on RR and on the net. I used keywords motrac repeater and got a lot of hits on old discussions, etc.
Also, the motrac and motran used the same receiver so you might want to expand your search a bit.
Don't discount info on UHF or low band models. These radios still shared a lot of commonality across frequency ranges. You may find answers in less likely places.
ffemt6488
troy mo
repeater
i will have pics up soon i found that if i turn up the volume on the repeter cabinet to max and the modulation on the controller i can hear the audio clear but not loud enogh to be able to use and hear properly ive tried measuing the voltage from the audio out of the reciever and the mic imput to the transmitter and both measure the same
jim202
New Orleans region
My guess is that your loading down the TX modulation point your using for the injection point. You need to remember that in most of the places that you can inject the audio, the connection needs to not load down that point. You might have to use something like a 47K value or larger of a series resistor.
Another point to consider is that there is probably a DC bias on the injection point your using. Your connection interface needs to take this into account also. Might have to add a series capacitor in your connection. If so, it probably wants to be in the order of at least 1.0 uf in size. This will insure that you have enough lows passed to prevent the TX audio from only having all high's.
My other concern is where your pulling off the received audio that your passing on to the repeater transmitter. You don't want to take it off the speaker connections. This source is variable depending on the volume control. You need a point that the RX audio is not changing.
ffemt6488
troy mo
I was thinking that were i was picking up the audio may be the problem any clues were is the best place to pick up the audio ? im working on getting up pictures of the project
Project25_MASTR
Millennial Graying OBT Guy
Texas
Do you know the history of it? Like where it was in use before you acquired it?
ffemt6488
troy mo
It was used at polite concrete in potosi missouri , I actualy got in contact with the guy who originaly serviced it and it was never used as a repeater just a glorified base radio with 2 remote extensions . I hooked up a original handheld mic and the transmit audio is crystal clear. if i hook up the controller the audio goes down a bit but still clear. i possibly may just make the trip and see if the guy will give me a hand and help me get this set up and working Correctly instead of frying something . I will say agin i am a novice radio guy and still learning.
Project25_MASTR
Texas
So it's a station. What is the controller on it? It could be that a pot is not properly tuned on the controller.
ffemt6488
troy mo
The controller im using is a CRP-101 china job and any off chance does anyone know how many watts, amps,volts ? does a oem motorola mice put out as far as audio , the mic in question is off of a Radius M400
jim202
New Orleans region
You didn't tell us that this is a simplex repeater control box. It listens to the receiver and then turns around and transmits 30 seconds of what it last heard. If 30 seconds is enough, then have at it.
If your looking for a true repeater operation, you will need to split the radio and also need a duplexer. I am not sure that this radio can be split into a receiver and transmitter that can have both working together at the same time.
