Need Help with T4Win
FuelForFire
The Garden State
First off, this is my first attempt at using trunker or any similar program and I am running a tapped BC785D to the sound card of my Windows XP SP2 computer. I gave trunker a try and after a couple hours of tinkering and no luck I moved on to T4Win with no more success.
I am monitoring the control channel of a Motorola Type II UHF system which comes with full signal on the scanner. When I run T4Win I get the scope view on the side active and the activity pane flies by but the decode rate stays at 0.0.
Any ideas what I might be doing wrong?
Thanks in advance,
Mike
w0sd
Salem South Dakota
Trunker
IMHO Stick with Trunker. There are a lot of people who know a lot more about using Trunker than I do but I can appreciate your lack of usccess. I have a lot of hours in learning so I would like to help.
Lets start with a question?
Can you run DOS?
Do you have a laptop or desktop?
What operating system are you using?
Ed W0SD
