Does anyone know if you can use the rear 232 serial port on the 996 to power the information to the rh96 instead of using the front data link. If so what pins do u use? Many thanks
I assume this is for WBAL TV's aircraft? Nice work on the rs232 engineering. That looks like a much more stable connection than the front connector, and allows you to have a dual-control head operation to boot!
OK let me rephrase that question, what pins are used for the GPS. I could be possible to make a break out that would control the head and the GPS from the back.
