Need help with XTS 1500
mikewazowski
Staff member
Forums Manager
Oot and Aboot
jim202
New Orleans region
You might be caught in the middle with not knowing what version of the programming software was last used on the radio. This is a common problem when you obtain a used radio.
You might ask the place you obtained the radio from if they have any idea what the last version of the programming software was used on your radio.
Jim
FFPM571
Nashvillle
Jim
has nothing to do with it.. He is trying to edit the trunking codeplug without a system key.
prcguy
Try programming a few conventional freqs and see if the radio takes it and if it works ok. That will verify the software is working with the radio and that the radio is functional. Also proving that something is not being provided to satisfy the software when programming a trunking system.
