need help
mattnelson26
Hopkins, Minnesota
i am with a club that does event and uses radios. but after the 1st of the year we cant use them do to fcc rules. Can anyone tell me how grms works and do you need to use repeaters if we just use portable radios?
thanks,
matt
quarterwave
TBD
I am assuming you mean your radios are not narrowband capable, and you do not want to replace them?
If you have a license (Itinerant or otherwise) you can modify it for narrowband and have your radios reprogrammed if capable. But again, I guess I need to assume you are asking because they are not.
The only "business" you can use GMRS for, is a family business, where all operators are family members and at least one has a GMRS license. (If you had an Itinerant license, this is where you may as well stick with what you had...versus changing only to pay for a new license and radios). So, again, if I assume your club is not family, and this is a business venture. You could not use GMRS. If it was not business (IE make money - for profit - paid to do it) you could possibly use it, but ALL members would need to hold licenses.
Getting too technical? You may want to share some more info. What kind of event, is the club a non-profit, what kind of radios do you have now, what frequency, what type of license do you have (Itinerant or coordinated....whats your call sign), etc.
I think myself and others can offer some suggestions.
In GMRS you do not have to use repeaters, there are low power channels, and high power channels, plus repeater pairs. If you were using only handhelds before and that worked, then you don't need a repeater anyway.
There is MURS (VHF - 2 watts) for business or personal, no individual license required. Also, FRS, which share some GMRS low power channels, but is licensed by rule as well (no indiv license) but on FRS you have people trying to use it for business, kids, legit people, etc. But, there are 14 channels and lots of privacy codes.
So, tell us more and we'll try to help.
mattnelson26
Hopkins, Minnesota
well i dont know the model of the radio. but it is old motorola and i think we are use vhf frequincy. events are going to parades and fire muster.
thanks,
matt
quarterwave
TBD
Well, I guess that's a tad bit more info. I think the suggestion, in lieu of answers, is probably FRS for ease of acquiring and matching radios to use as a group, or MURS VHF if you need a little more range outdoors.
stmills
Twin Cites Area MN
GMRS would require each member of the club to get a $75 license from the FCC. You have the option to uses simplex channels or repeaters. You can mix GMRS and FRS radios together since FRS 1-7 are part of the pool of channels available to GMRS license holders, but the GMRS users can use 5 watts to the FRS 1/2 watt of power.
