Need Info on the NMN6247 PSM
rmiles
I'm looking for some information contained in the instruction manual for the NMN6247 PSM. I need to confirm the Motorola Part Numbers of two items. Is the antenna bushing seal P/N 3205782P01, and is the tool for mounting and de-mounting the NTN8327 RF adapter NTN8270? Could someone also please send me the manual number for the PSM instruction manual. I've misplaced mine and need to order anouther copy. If someone has the manual in PDF or other type of file format, I'll provide you with my email address to send it to.
Thanks!
Ron
greenthumb
Colorado DB Administrator
3205782P01 is listed as "SEAL ANT BUSHING Unit of Measure: 5 PK"
NTN8270 is listed as "TOOL WRENCH Unit of Measure: 1 EA"
If you're still hesistant on what these are, call Motorola at 1-800-422-4210. You'll be paying GOOD money to order the parts that aren't manufactured for more than 1/2 of what you'll be paying, so you might as well get the customer service time for your buck :) The Parts ID department would be glad to help you out. I think that it will be options 1 then 2 to get you to parts ID, but listen to the recording to make sure :)
rmiles
greenthumb, thanks for the info. Actually, I already got that info from MOL (Motorla on Line) which is where I suspect you got those discriptions from. I was looking to see if anyone had the instruction sheet that came with the PSM and could write me the P/N listed within.
Thanks for your reply!
Ron
Mozilla
South Florida
Part numbers
I just opened two different boxes with the mikes and neither one has documentation that includes the part numbers other than the mike number and the RF adapter... it mentions the wrench but not by part number. The only parts list is for the antenna and the box and RF adapter sheet also does not mention a part number for either part you are requesting.
rmiles
Mozilla, Thanks for the reply. I must have seen them listed somewhere else. Could you forward me the P/N for the sheets you have? I'm getting ready to submit a parts order and would like to order the instruction sheet so I can give it to the customer with the mic and RF adapter.
