Need info on three magnet mobile antenna mount.
Delray Beach, FL
I have had this mount sitting in my trunk for a few years now. I used to use it with a quick connect for my whips. Now, I believe a missing piece fell off and I havent a clue how to connect an antenna to it now. Can someone who may own one of these, take a pic, or tell me what should go on this. Thanks.
slowmover
Fort Worth
That removeable center section can be swapped for another type
I have one uses this:
You “may” have to enlarge hole in arm.
I had to use washers and longer bolts on the feet to raise the center section.
New coax.
The Hustler QD is the best known of its type (not needed, though):
Your start is that you need to disassemble that thing — completely (get new fasteners) — and clean corrosion completely. Threads, everything.
0000 steel wool & Flitz will do most of it.
