Need Installation Advice
Metrofire31
Auburn-Opelika, AL
I have just purchased a Yaesu FT7800R (with modified freq coverage) and plan to install it in my Mercedes ML-350. However, my questions are almost irregardless of the type vehicle. I plan to mount the remote head on my dash/console on top of my BC-RH96. I'm curious about the best place to mount the radio itself? And also how to connect the electrical wires - should it go to the battery or is it OK to connect in the fuse box? If it's to the battery, I'm not sure the cables they provided are long enough - what is best to use to extend them and how do you connect them?
Lots of questions but I appreciate the advice that's so readily available from all you guys.
paramedszaf
Kingston, Pa - Luzerne Co.
#1 - a Mercedes WOW!
#2 - Is there an in-line fuse? If so what is the amp rating? How many watts is the radio? Usually a 15 amp will handle it.
#3 - Need pic of the passanger compartment to make a good determination where to mount.
n8emr
You just dumped $50k plus in to the vehicle. find a two way shop spend a couple hundred bucks and have it done correctly.
n9mxq
Belvidere IL
Under a seat or in the trunk for the main body of the radio.
Run the power straight to the battery will be your best bet. Use wire of the same gauge as the power cable on the radio, or maybe even a tad bigger to run the power.
MAKE SURE IT'S FUSED! Never bypass fuses.
When you get it all done, post up some pictures... I'd love to see the results..(Even if you have a shop do it)
Metrofire31
Auburn-Opelika, AL
Advice
Good advice guys - I'm going to have the local shop install it. They do all the county/city PD cars. Thanks for the super advice.
hoser147
Grand Lake St. Marys Ohio
While on the topic of fusing, the commercial outfit that takes care of our radio's fuses the ground also. As far as extending the power and ground wires its no big deal, if you have any experience in installing at all you should be able to do it yourself, however if you are not comfortable with that it would be best to have it done............Hoser
