Need Miramar & Edwards AFB freqs
N9JCQ
Lake Barrington, IL
Guys, can anyone supply me with the aviation frequencies for Mrramar MCAS and Edwards? I will be on vacation in the LA area soon and want to try and listen to as much milair as possible
Joe
SkipSanders
Silent Key
MIRAMAR MCAS, (MITSCHER FLD) CA KNKX MC N32°52.10' W117°08.50' 477
UTC-8(-7DT) H-4H, L-4H
SERVICE - LGT - PAPI RRP not coincidental with PAR Rwy 24L. PAPI units for Rwy 06L/R are
optimized for hgt group 2 type acft. ACTIVATE-ALSF-1, HIRL, CL and PAPI Rwy
06L-24R-298.925 or 133.475. A-GEAR - Short fld A-GEAR Rwy 24R nml de-rigged.
JASU - (NC-10A1) (NC-10C) (A/M47A-4) FUEL - J5 FLUID - SP LHOX LOX OIL -
O-148-156 TRAN ALERT - No AMC fleet svc avbl. ALCE team rqr for all AMC flt. Ltd tran
svc, no tie-down, oil/laboratory analysis or tran maint svc avbl. No shuttle svc avbl. All VIP
acft ctc Airfield OPS on PTD 15 min prior to arr.
REMARKS - Opr 1530-0800Z++ Mon-Thu; 1530-0200Z++ Fri; 2200-0200Z++ Sun; clsd Sat
and hol. See FLIP AP/1 Supplementary Arpt Info. RSTD - PPR for all tran acft ctc VAL DSN
267-4284/85, C858-577-4284/85 (PPR rstd to 30 min before/after approved time, PPR not
valid outside of this window and must be re-coord prior to arr). Prior coord rqr for
AMC/NALO msn with Airfield OPS DSN 267-4419/4277, C858-577-4419/4277. After nml
working hr DSN 267-4028/4029/4277, C858-577-4028/4029/4277. 24 hr PN for acft with
haz cargo. All acft det will rqr a host unit and stn Comdr apvl 90 days prior. For staging (lcl
trng flt) or VIP acft ctc VAL DSN 267-4284/85, C858-577-4284/85. CAUTION - Hi mid-air
potential, exer extreme vigilance. Water on the rubber build-up areas of the rwy may
produce poor traction and/or BA and standing water on rwy may produce hydroplaning
cond. Extv general avn tfc all alt, all drct near afld. Hi volume civ VFR tfc along coast W of
afld. All acft arr/dep VFR via corridor rules to/fr coastline are advs to exer extreme caution
to avoid hang glider act near Torry Pines golf crs, NKX R-280/5 DME. TFC PAT - Reduced
rwy separation std in eff USN/USMC acft. Opr on parl rwy 700' apart. Multi practice apch
Rwy 06L/R not auth. Radar vectors to final apch, exp steep descent. Rwy 10 not avbl and
Rwy 28 emerg use only. NS ABTMT - Strictly enforced mandatory pro and crs rules. All
tran acft must review and sign Ns Abtmt form with flt planning. MISC - Ordnance, live or
inert, not perms to remain on RON tran acft.
COMMUNICATIONS - SFA PTD - 335.625 ATIS - 352.0 SOCAL APP - Opr H24. (R) (E)
132.2 269.1 288.325 REMARKS: (288.325 Acft dep W291 for NKX arr.) TWR - (E) 135.2
298.925 340.2 GND - 128.625 307.325 SOCAL DEP - (R) (E) 119.6 132.2 269.1 363.1
CLNC DEL - 125.975 254.325 PMSV METRO - Opr H24. 342.4
FSS-SAN DIEGO SAN-NOTAM NKX
NAVAIDS - MIRAMAR TACAN - L NKX CH 33 N32°52.18' W117°09.29' At Fld.
431/(A)15°00.0'E
ILS/RADAR - ILS/RADAR - SEE TERMINAL FLIP FOR RADAR MINIMA.
EDWARDS AF AUX NORTH BASE, CA K9L2 AF (NASA)
N34°59.45' W117°51.79' 2299 UTC-8(-7DT) H-4H, L-7C
SERVICE - LGT - HIRL-Rwy 06-24 nstd. Rwy edge lgt posn more than 10' fr edge of usable
sfc.
REMARKS - Opr 1400-0600Z++, clsd wkend and hol. RSTD - PPR strictly enforced. Clsd to
all tran acft wo prior apvl of 412 OG/CC. All turns will be made on conc areas of rwy lctd at
the apch end, dep end and mid-fld. If unable to exit a cntr twy, acft must proceed to dep
end to initiate turn and exit mid-fld.
COMMUNICATIONS - SPORT APP/DEP - (R) (E) 132.75 343.7 REMARKS: Opr 1500-0100Z
(DT 1400-0200Z) Mon-Fri, wkend as rqr; OT ctc JOSHUA APP DEP 133.65 348.7.-
TWR - (E) 120.7 318.1 353.6 FSS-RIVERSIDE RAL-NOTAM KEDW
NAVAIDS - EDWARDS VORTAC - L 116.400 EDW CH 111 N34°58.94' W117°43.96' 261°
6.4 NM to Fld. 2354/(A)15°00.0'E
EDWARDS AFB, CA KEDW AF (NASA) N34°54.98' W117°51.75' 2310 UTC-8(-7DT)
H-4H, L-7C
SERVICE - L-AOE LGT - ILS and PAPI not coincidental. JASU - (MD-3) (MD-3M) 2(C-26)
8(AM32A-60) (MA-1A) (MC-1A) 2(MC-11) FUEL - 2 hr refuel delay can be exp. 100 - Avbl
thru prior arng with Aero Club only DSN 525-8321, C661-275-8321; J5, J8 Can no longer
refuel/defuel with J4. FLUID - SOAP W SP PRESAIR LHOX LOX OIL - O-128-133-148
TRAN ALERT - Svc avbl 1400-0600Z++ wkd; 1400-0200Z++ wkend and hol 24 hr PN.
Transportation svc avbl 1400-2300Z++ wkd; Exp svc delay wkend and hol. Ltd fleet svc
avbl. No priority basis.
(B) RWY-05
3506→
(4022x100 ASP S30 T46) RWY-23
RWY-17 L1,2,6,15,50 (5002x100 ASP S31 T70 ST88) L1,6,9 RWY-35
←4515
VKN NDB unuse 060°-200° byd 19 NM
RWY-06 L5 (5998x150 ASP PCN 48 F/A/W/T) L5,50 RWY-24
EDW TACAN unuse 090°-150° byd 15 NM
(B) RWY-04L (11998x200 ASP PCN 54 F/A/W/T) RWY-22R
RWY-04R L5,50,53,54 (15024x300 CON PCN 70 R/B/W/T) L5,9,50,53,54 RWY-22L
HOOK BAK-12B(B) (1518') HOOK BAK-12B(B) (1559')
RWY-06 (8000x50 CON PCN 6 R/D/W/T) RWY-24
Effective 11 FEB 2010 - 8 APR 2010
AIRPORT/FACILITY DIRECTORY B-195
REMARKS - Opr 1400-0600Z++ Mon-Fri; weekends by NOTAM, clsd hol and ev third Sun
for const and maint. See FLIP AP/1, Flt Haz and Supplementary Arpt Rmk. RSTD - OFFL
BUS ONLY on wkend and hol, PPR always. Ctc Base OPS DSN 527-2222/3571,
C661-277-2222/3571 for PPR Nr. PPR and airspace briefing rqr for all acft (no exc), tran
should be prior coord in advance with airspace mgr DSN 527-2446. All PPR rqr min 24 hr
PN, no same day PPR avbl. PPR will not be issued more than 5 days prior to arr. All PPR
valid +/- 30 min PPR time. Fone coord rqr for PPR outside of block time. Practice apch to
Edwards AFB main base rwy, North Base rwy and lake bed rwy proh when twr clsd. Ctc
NASA Flt OPS C661-276-3213 exc for PPR. Non-NASA registered acft must ctc NASA to
prk on NASA ramp. S base Rwy 06-24 clsd offl SS-SR. S base is limited to light acft 12,500'
or less, no turbojets. Rwy 04L-22R daylt only ops. CAUTION - VFR initial flown 1215' N of
rwy cntrline due to steep str-in simulated flame out and shuttle apch to rwy. Pay careful
attn to acft alignment on final to preclude inadvertent ldg on S base Rwy 24. Numerous
unmrk/unlgtd obst sur arpt. Observer vis rstd SW-N due bldg obst vision. Use caution for
UAS arr/dep from Rwy 04L-22R, S Base Rwy 06-24, N Base Rwy 06-24, the
Rogers/Rosamond Rwy complex and within R-2515. Ctc ATC for UAS act. NS ABTMT -
Rwy 22L/R: All IFR dep exc lo performance acft (C12, T1, etc) whose initial turn is SW-N, fly
rwy hdg til 12 DME before turning on crs. MISC - Tran acft may exp IFR separation delays
entering R2508 Complex. Tran acft exp extv reful delays. Acft with DV inbd ctc PTD 40 NM
out. No COMSEC avbl; aircrew ltd to own resources on arr or in case of extv delay. Multiple
acft rqr 24 hr PN. UHF eqpt acft must use UHF (not VHF) in pat. No RVR capabilities. Class
D Airspace eff 1400-0600Z++, exc hol and ev third Sun for const and maint, OT Class E.
Cargo acft rqr support must arr prior to 0200Z++. No Space A PAX support avbl.
COMMUNICATIONS - PTD - 372.2 ATIS - Opr 1400-0600Z++. 269.9
SPORT APP/DEP - (R) (E) 132.75 343.7 REMARKS: Opr 1500-0100Z (DT 1400-0200Z)
Mon-Fri, wkend as rqr; OT ctc JOSHUA APP/DEP (133.15 269.2 E) (126.1 290.3 S)(133.65
348.7 W and N). TWR - (E) 120.7 318.1 353.6 GND - 121.8 225.4
COMD POST - 304.0 REMARKS: CONFORM PMSV METRO - Full svc 1300-0600Z++, clsd
hol. 342.4 REMARKS: After hr wx briefings/updates avbl fr the 25 OWS at DSN
228-6958/6599/6588 or toll free C877-451-8367 ext 1. NASA FLT OPS - 135.825 373.15
NAVAIDS - EDWARDS VORTAC - L 116.400 EDW CH 111 N34°58.94' W117°43.96' 225°
7.5 NM to Fld. 2354/(A)15°00.0'E
ILS/RADAR - ILS - Lczr lctd dep EOR 22L.
MtnBiker2005
San Diego County, California
KEDW - Edwards Air Force Base
http://airnav.com/airport/KEDW
KNKX - Miramar Marine Corps Air Station
http://airnav.com/airport/KNKX
San Diego Regional Naval System - Miramar Fire/Police is on it.
http://www.radioreference.com/apps/db/?sid=812
Edwards Air Force Base - Motorola Type II with P25 digital audio.
http://www.lazygranch.com/edtrunk.htm
http://www.radioreference.com/apps/db/?sid=3382
A new Motorola Type II system at Miramar.
389.5125 - NAC 293 - P25 - Might be the prison at Miramar base.
386.9000 - NAC 293 - P25 - Might be the prison at Miramar base.
Others:
SoCalMilCom - YahooGroup.
http://groups.yahoo.com/group/socalmilcom
KNZY - North Island Naval Air Station (Halsey Field)
http://airnav.com/airport/KNZY
KNFG - Camp Pendleton MCAS (Munn Field) Airport
http://airnav.com/airport/KNFG
bryan_herbert
Las Vegas, NV. DM26jc
If youre gonna be near Edwards youll be in the belly of R2508, here are the freqs youll want to monitor while in R2508.
AF PLANT 42
114.5000 VORTAC
118.2750 ASOS
121.9000 GROUND
348.6000 GROUND
123.7000 TOWER
317.6000 TOWER
121.5000 GUARD
243.0000 GUARD
123.2750 PRODUCTION FLIGHT TEST CENTER
275.2000 PRODUCTION FLIGHT TEST CENTER
301.7000 PRODUCTION FLIGHT TEST CENTER
334.7000 PRODUCTION FLIGHT TEST CENTER
CHINA LAKE NAWC
322.3750 ATIS
274.7000 CLEARANCE
360.2000 GROUND
120.1500 TOWER
340.2000 TOWER
343.1500 METRO
121.5000 GUARD
243.0000 GUARD
282.8000 SEARCH AND RESCUE
346.4500 VX-9 VAMPIRE OPS
376.0750 VX-9 VAMPIRE TAC
246.8000 VX-9 VAMPIRE TAC
256.2750 VX-31 COSO OPS
398.7000 VX-31 COSO TAC
362.5250 INTEGRATED BATTLESPACE ARENA 'IBAR'
128.2500 CHINA CONTROL 'SAFETY OF FLIGHT'
301.0000 CHINA CONTROL 'SAFETY OF FLIGHT'
369.3000 CHINA CONTROL 'ALPHA RANGE'
320.6500 CHINA CONTROL 'COSO RANGE'
126.0500 CHINA CONTROL 'ECHO RANGE'
381.9000 CHINA CONTROL 'ECHO RANGE - PRIMARY'
386.0500 CHINA CONTROL 'ECHO RANGE - SECONDARY'
336.4500 CHINA CONTROL 'SUPERIOR VALLEY SECONDARY'
362.0000 CHINA CONTROL 'SUPERIOR VALLEY PRIMARY'
315.9000 LOW LEVEL 'TRONA CORRIDOR'
EDWARDS AFB
116.4000 ATIS
269.9000 ATIS
121.8000 GROUND
225.4000 GROUND
120.7000 TOWER
318.1000 TOWER - PRIMARY
353.6000 TOWER - SECONDARY
342.4000 METRO
304.0000 COMMAND POST
372.2000 DISPATCH
308.7000 SOF / TECH ASSIST
121.5000 GUARD
243.0000 GUARD
141.1000 ARMY AVIATION
339.9000 ARMY AVIATION
149.1500 COBRA OPS
239.9500 COBRA OPS
228.9500 DAGGER OPS
322.7000 DAGGER OPS
300.8000 EAGLE OPS
385.9000 GHOST OPS
136.2250 GLOBAL OPS
314.2000 GLOBAL OPS
349.3000 GLOBAL OPS
030.8500 MOONLIGHT OPS
138.6250 MOONLIGHT OPS
293.3500 MOONLIGHT OPS
326.4250 MOONLIGHT OPS
139.7750 RAPTOR OPS
230.2750 RAPTOR OPS
290.8000 RAPTOR OPS
034.5500 ROADHOG OPS
140.3000 ROADHOG OPS
307.5250 ROADHOG OPS
363.4500 ROADHOG OPS
123.1500 TIGER OPS
251.2500 TIGER OPS
257.0750 TIGER OPS
267.8000 TIGER OPS
379.7000 TIGER OPS
136.4250 TORCH OPS
266.3000 TORCH OPS
276.6500 TORCH OPS
279.9000 TORCH OPS
287.2000 TORCH OPS
324.7000 TORCH OPS
383.2000 TORCH OPS
141.5250 TROUT OPS
315.2000 VORON OPS
138.0000 X-RAY CONTROL
290.7000 X-RAY CONTROL
141.5500 ZOOM OPS
311.2000 ZOOM OPS
286.4000 MISSION
294.6000 MISSION
286.8000 TPS MISSION
375.0250 TPS MISSION
391.1000 TPS MISSION
135.8250 NASA 4
373.1500 NASA 4
134.1000 NASA MISSION
237.0000 NASA MISSION
259.7000 NASA SPACE SHUTTLE DOWNLINK
296.8000 NASA SPACE SHUTTLE UPLINK
339.2250 R-2515 AIR REFUEL
132.7500 SPORT CONTROL - SAFETY OF FLIGHT
343.7000 SPORT CONTROL - SAFETY OF FLIGHT
225.6500 SPORT CONTROL - RANGE OPS
264.6000 SPORT CONTROL - RANGE OPS
272.0000 SPORT CONTROL - RANGE OPS
276.6000 SPORT CONTROL - RANGE OPS
280.1000 SPORT CONTROL - RANGE OPS
286.6000 SPORT CONTROL - RANGE OPS
292.3000 SPORT CONTROL - RANGE OPS
297.4000 SPORT CONTROL - RANGE OPS
305.9500 SPORT CONTROL - RANGE OPS
322.5000 SPORT CONTROL - RANGE OPS
325.1000 SPORT CONTROL - RANGE OPS
325.9000 SPORT CONTROL - RANGE OPS
336.4000 SPORT CONTROL - RANGE OPS
378.1000 SPORT CONTROL - RANGE OPS
FORT IRWIN NTC
036.8000 ROZ 1 - BICYCLE LAKE AAF
041.5000 ROZ 1 - BICYCLE LAKE AAF
118.1750 ROZ 1 - BICYCLE LAKE AAF
281.4500 ROZ 1 - BICYCLE LAKE AAF
139.2500 COYOTE TOWER
232.8000 COYOTE TOWER
123.0000 BARSTOW-DAGGETT UNICOM
047.0000 BARSTOW-DAGGETT CRASH/RESCUE
046.7000 BARSTOW-DAGGETT AVCO - HAWK 86
038.6000 COYOTE METRO
032.4500 GRANITE METRO
121.5000 GUARD
243.0000 GUARD
038.4750 MEDEVAC / DUSTOFF
038.9000 MEDEVAC / DUSTOFF
036.7000 COMMAND POST - BIKE OPS
134.1000 COMMAND POST - BIKE OPS
034.8500 D/158TH FLIGHT OPS
148.6000 D/158TH FLIGHT OPS
304.3000 D/158TH FLIGHT OPS
048.4500 FIRE CONTROL
032.7000 RANGE CONTROL
038.9000 RANGE CONTROL
319.2500 BICYCLE LAKE CONTROL
268.0000 LEACH LAKE RANGE
381.1000 LEACH LAKE RANGE
041.6500 DESERT RADIO - NORTH
302.3000 DESERT RADIO - NORTH
036.5250 DESERT RADIO - SOUTH
041.0000 DESERT RADIO - SOUTH
126.2000 DESERT RADIO - SOUTH
339.8500 DESERT RADIO - SOUTH
398.1500 SUNDANCE ADVISORY
399.8500 SUNDANCE ADVISORY
R2508 RANGE CONTROL 'JOSHUA APPROACH'
134.0500 ISABELLA MOA
335.6000 ISABELLA MOA
133.6500 ISABELLA MOA 'PRIMARY ATC'
348.7000 ISABELLA MOA 'PRIMARY ATC'
126.5500 OWENS MOA
322.3000 OWENS MOA
123.9500 SALINE MOA
256.8000 SALINE MOA
120.2500 PANAMINT MOA
291.6000 PANAMINT MOA
124.5500 PALMDALE
363.0000 PALMDALE
126.1000 PALMDALE
290.3000 PALMDALE
R2515 RANGE CONTROL 'SPORT'
LOS ANGELES ARTCC - LA CENTER
127.1000 BAKERSFIELD
317.7000 BAKERSFIELD
125.7250 BARSTOW
126.3500 BARSTOW
132.3000 BARSTOW
132.5000 BARSTOW
133.5500 BARSTOW
134.6500 BARSTOW
279.6000 BARSTOW
284.7000 BARSTOW
290.2000 BARSTOW
317.4000 BARSTOW
351.9000 BARSTOW
360.6500 BARSTOW
369.9000 BARSTOW 'ULTRA HIGH ALTITUDE'
128.3750 LEBEC
135.3000 LEBEC
263.0000 LEBEC
372.0000 LEBEC
125.2750 PALMDALE
132.5000 PALMDALE
284.7000 PALMDALE
351.7000 PALMDALE
125.8000 SADDLE PEAK
132.6000 SADDLE PEAK
307.1000 SADDLE PEAK
351.8000 SADDLE PEAK
124.6250 TONOPAH
290.2000 TONOPAH
377.1000 TONOPAH
