Need Motorola MT 2000 help
nofdexplorer406
Bedford, Kentucky 40006
I just purchased a MT 2000 with R02.13 also got the cord and the rs232 to USB converter, my question is how do I get the radio in programming mode also being the radio is R02.13 does the software have to be above or below that number kinda new to Motorola programming use to kenwood
KG4INW
Midlothian, VA
There is no programming mode. You attach the RIB to the computer, turn it on, attach the radio to the RIB, turn it on and then read the radio with the DOS based RSS. There is no Windows based CPS for the MT2000. If you have a so called RIBless cable, you follow the same procedure (the RIB is actually built into the cable).
You can only program the radio with the highest level it was last programmed with, whatever that may be.
