Need pinout - PCS Programming Cable TQ-3336
smackdaddy
Hello Everyone,
I'm trying to build a PCS programming cable. Once again I have found that the information that is publicly available about these Ericsson programming cables is incorrect. I have tried to use the following pinout:
<pre>
DB25 UDC
17 2
14 1
1 5
12 4
11 3
</pre>
I have identified the pin numbers for the UDC according to the service manual. I'm using the following configuration:
<pre>
o - pin 3
o - pin 5
o - pin 4
o - pin 1 o - pin 2
</PRE>
If anyone has a PCS programming cable, could you please confirm these pinouts with a continuity tester? I would be forever in your debt :)
Cheers,
SD.
smackdaddy
Hello Everyone,
With the help of a very helpful fellow over at Price Industries, I have been able to solve the mystery of the PCS programming cable.
On the UDC connector of the PCS radio, there is a small micro switch which must be depressed in order to program the radio. This is hidden under a piece of rubber.
Otherwise the advertised pin configuration is correct.
Cheers,
SD.
