Need Pro-18 Firmware
minasha
NYC
Can someone please pm me the Pro-18 firmware file.
I want to repair my scanner and all I need is the file to load firmware.
I don't want to send it in for the Legacy upgrade as I have no need for DMR
Thank You
Swipesy
Northern Ohio
I have a iScanPro18.zip file that contains the following. Will this help you?
kruser
Well Known Member
W St Louis Cnty, MO
Yep, you need to see if anyone has the standalone CPU updater file.
I don't recall if one was ever released for the Pro-18 though but if so and you can get someone to email it to you, you should be able to get yours going again.
Having the original iScan software installed is not going to help as the server it connects with is long gone now.
The Pro18 can be upgraded by Whistler like the PSR800 can, that may be your only option. That upgrade basically makes your Pro-18 into a Whistler WS1080 and adds DMR support to boot. It does not follow trunked DMR systems though but you can listen to DMR signals conventionally one channel at a time.
If your Pro-18 is in fairly good physical shape, it's probably worth sending to Whistler to get the upgrade.
Here's the link to Whistler's Legacy Model upgrade page: https://whistlergroup.com/products/upgrade
Once upgraded, you install and use Whistler's free WS1080 version of EzScan software to get weekly DB updates and also use that to manually program or change things in your Pro18. Just remember that it's considered a Whistler WS1080 now.
jaspence
Michigan
I have a Pro-18 and a GRE 800 with the upgrade. The DMR is a very small part of the update. It improved the performance of both radios and in my situation greatly reduced the simulcast problems. If you go that route, be sure to download the CPS from Whistler. The old software will no longer work with the radio,
Wackyracer
Send it to whistler for the legacy upgrade that makes it a ws1080 in a pro-18 case...go to whistlergroup.com
