Marchboom
That varies by model, so you'll need to be more specific.
With spending the same amount of money, would the mobile/base unit be better/have more features than a handheld?
Sorry, no.With spending the same amount of money, would the mobile/base unit be better/have more features than a handheld?
Generally speaking, the handheld version of the desktop model, i.e. Uniden 536HP/436HP or Uniden SDS200/100 or Whistler WS1065/1040, will have similar performance characteristics when connected to the same antenna.Besides the speaker size and the controls layout, are the inner workings, reception capability, etc the same for both units?
I generally prefer handheld scanners. Besides being portable, whether carried around, or simply picked up & moved to either a different spot in the house, or to my vehicle, they are battery powered. If used at home, or in a vehicle, where external power is available, then the batteries are not used. However, in the event of an extended power outage, the handheld will keep going as long as you have charged (rechargeable) batteries, or, for many handhelds, alkaline AA batteries. For the newer model scanners, which are powered via the USB port, one of the power packs used to recharge a cellphone or tablet can power a portable scanner for an extended time.I am getting back into monitoring and want to get a new scanner. Not sure if I want a handheld or a mobile base unit. I have a BC100 handheld now but 95% of the time I will be in the house listening.
How many of you bought the handheld units, use them inside most of the time are are glad that you got this one over a mobile/base unit? Who would rather switch out their handheld for a mobile/base unit?
Of those who have have, or have had both units, what type did you like the best?
Your opinions are appreciated.
I like the bookends idea. I too have a RAM mount in my truck for my GPS. They work great.As to mounting:
At home I use metal bookends. A slight bend provides the optimum angle.
In the vehicle I use a RAM mounts or the like. It is a mostly rigid yet flexible arm that mounts to the front seat bolt that one can attached whatever device to.
Probably so but I didn't want to put to many questions into one post.You've got multiple threads on essentially the same subject. You should ask a Mod to merge them as they generally frown on duplicate posts.
