i just used the program to program my scanner now it is still cycling through all the systems that it had pre stored on the scanner. is there a button i can push to just select one system and stay in that one. or is it always going to cycle through them all. please help. I just got this scanner and it is already becoming clear that it is very difficult to program even with free scan are their any youtube instructional videos out there i can't find any on how to program freescan with this thing to be able to scan the talk groups and sites i programmed into it besides it scanning all the preprogammed systems on it i am at a loss at how to program this scanner coming from a whistler and radioshack and g4 pager this scanner is so different any help appreciated
Are you referring to the various systems loaded in the scanner memory when first shipped, or after you have done a reset?
If you are speaking of the pre=programmed systems, there are two ways to eliminate them.
Presuming that you have your programming file already created, and saved, in FreeSCAN, then resetting the scanner will wipe the memory clean. You would need to again load your file, but no other systems will be already programmed if you do the reset correctly.
With the scanner off, press & hold down these three keys on the keypad:
2,
9, and
Hold.
Continue to hold down those keys while hitting the power button to turn the scanner on. As the scanner boots up, you should get a message that you will be deleting everything programmed in the scanner at that time. Proceed through the reset. If I recall correctly, after the memory is cleared, you will get a prompt asking if you want to re-load the pre-programmed systems. You don't. That list is from when the scanner was first introduced back in 2005. Probably just about all of the pre-loads are no longer current or correct.
The other method is to have FreeSCAN clear the scanner's memory when you load your file. You do that by checking a box on the download menu that pops up when uploading programming to the scanner.
If, instead, you are referring to the various service searches, that can be disabled using the Scanner Settings option in FreeSCAN.
Select that option, and that will take you to a sub-menu where you can make changes.
There is a User Guide for FreeSCAN in the Wiki.
wiki.radioreference.com
