Need some advice on a mobile install
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
Hi if someone can help me i need some advice on a install on where i could put my scanner in a 1998 chevy caviler i can't figure out where i could put a scanner holder and where i might get one so i don't have to drill holes in the dash is there any scanner holders on the web i can buy with a Velcro back to glue to use on the dash?Would greatly appreciate any advice.
af5rn
N. Tex / S. Fla
Knowing what kind of scanner you are talking about would be helpful. Some will work fine with velcro on a dashboard. Others are too large and/or heavy. Others have remote heads available, saving you the trouble.
fmulder13
Minneapolis, MN
If you've got a pro-96, you're in luck in a way, because portable scanners tend to be more easily installed then base/mobile scanners, especially for people in your situation who don't want to do a lot of drilling, etc. There are a number of products out there that mount objects like iPods, cell phones, GPS devices, etc. and do it via a mount that goes in the cupholder, mounts to an air vent, mounts to the dash via adhesive, or mounts to the windshield. If you shop around you can find those mounts, and find just the right one to fit your scanner, and mount it in a way and in a spot that works for you. Best of luck, and post what you come up with!
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
Thanks for the info but do you know of some internet stores where i could get these cup holders from i can't find any when i search for them thanks.
N0GTG
Scanner programmer since 1997
Denver, Colorado
I've used the Panavise InDash bracket in my car for several years now, uses existing bolts, and they make custom brackets for each car. It puts the radio exactly where I want it - I can see it, and it can see out the windshield, which makes it receive much better. http://www.panavise.com/f/comm/indash/index.html
Attached to the bracket I have a Panavise Clip Caddy, which accepts a belt clip or button back. It can also be attached to the dash with self-adhesive strips (included), or screws (included), and comes with a couple of adhesive buttons to attach to your radio/phone/etc. I love it!
http://www.panaviseonline.com/product.php?id=345
If you can't locate them locally, private e-mail me, and I'll get them for you.
W4KRR
Coconut Creek
Can someone help me out?
They make a flexable gooseneck mount that attaches to the front seat mounting bolt on the floorboard of the vehicle. No holes to drill, no Velcro or glue needed. You just loosen the seat mounting bolt, slip the mounting foot under the bolt, and tighten it down. The scanner is held in place on the mount, and can be adjusted to whatever angle you want. If you want I can get you a link later, and maybe post a picture of such an arrangement.
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
Can you get me the link for this and post a pic of it?
W4KRR
Coconut Creek
Visit this website:
http://www.mountguys.com/category_s/5.htm
There's a pic of the mount at the top of this page. It's called the "Car Floor Scanner Mount System". I have this mount, and I use it in a Ford Ranger pickup truck. It works out well as it is. The mount uses a padded clamp type arrangement to hold the scanner. I have modified mine with a Panavise 777 Clip Caddy instead of the stock mount. The Panavise 777 Clip Caddy will accommodate belt clips or the "button" style mount such as the type found on the Uniden BCD396T scanner.
I have ordered from The Mount Guys a few times, I have never had a problem with them. The Panavise 777 Clip Caddy can be purchased from many places, here's one:
http://www.awswireless.com/store/panavise-777.html
