need some advice
dallascowboys
Dothan Alabama
I have the radio shack pro 164, I also have the software and the long cable to program my scanner, but the software sayes I must buy the software that I want is this true? and looking at the software it looks complicated to do is this true? can you help me please.
KC5EIB
Flower Mound, TX
Go to Software for RadioShack PRO-series (PRO-92, 93, 95, 96, 97, 99, 163, 164, 106, 197) and GRE PSR-series (PSR-500, 600, 300, 400, 310, 410) scanners, download WIN97, try it out during the 30 day FREE period. If you like it and want to continte using it, pay the $35 lifetime fee.
Ensnared
Waco, Texas
Programming Pro-164
Let me see I can help you. From what I see, you have a Pro-164 analog scanner which is made by GRE for Radio Shack:
Pro-164 - The RadioReference Wiki
You can review some of the information associated with this radio.
Sometimes, scanners that use USB programming cables come with the software needed to program the radio the the computer. That is the sole purpose of this software.
However, there is different software available for those who want to program the radio using this USB connection. You can program your radio without this software; however, this can be labor intensive.
After you successfully program the USB cable between your radio and computer, you might want to invest in Win500, software needed to program the radio.
When I looked at Houston County, I saw where some agencies are using LTR radio systems. Radio Reference mentioned the possibility of Houston county joining a P25 digital system in your area.
If this transpires, you won't be able to hear these digital systems without buying a digital scanner. You might check with friends in the area to see when this might come to pass.
Sometimes, the Pro-106 digital hand held scanner can be purchased at a significant savings in pawn shops or through Radio Shack during sales. I don't know if the cable you possess will also work with the Pro-106. I would surely keep what you have until you know for sure which path to take.
gmclam
Fair Oaks, CA
Pro-164 (psr-300)
Yes, if you want to use software to program your scanner. Don't confuse software to program your scanner with the software driver for the cable.
It is not nearly as complicated to use the software as it is to program the scanner directly by hand.
There is a ton of information on this site regarding this specific issue. The Wiki is a great place to start. Good luck.
