I own a couple of Uniden BCD436HP radios and have manually programmed them to everything around me. Given almost all of the systems are Motorola Smartzone II. Just recently a neighboring county went from all conventional to the Viper system and I have a couple of questions that I hope someone has the answers to. First off I am trying to program Davidson County North Carolina if anyone wants to look it up on the database to help out. First question may seem like a dumb one but I can’t find any information to answer it. When programming a Viper system which radio system do you set it up as in your scanner? Second is I’ve programmed quite a few systems in the scanners and they all had a seven digit frequency so they were easy. Now trying to program this Viper system every frequency is an eight digit frequency like 769.55625. I can’t figure out which KHz range it is so when I enter the frequency it cuts off the last number so ofcourse it’s useless. Even if I knew the KHz range I’m not 100% sure I know where in the radio I would go to change it and set it up. If anybody could help me to get it right and explain it to me I would greatly appreciate it.
