Need some help for someone with exp.
Ferrum, Virginia
Started to use a Bearcat 210 Scanner in secluded part of Franklin County Va. Wondering if it will be strong enough to pick up the signal from local PD. Not familiar with what type of antenna to use. Seen a site Copper Catus J-Pole and wondered if it would be worth trying to build if it would help me or not. Franklin County is still analog from what I gather. Thanks for anyone's help.
W8RMH
Feed Provider Since 2012
You won't be able to receive any frequency which shows a mode of "P25" which is digital.
Franklin County, Virginia (VA) Scanner Frequencies and Radio Frequency Reference
Also I don't know if the 210 will receive the narrow band frequencies. (154.22750,154.09250).
They are VHF which usually has good range. Try a back-of-set antenna first.
N8IAA
Fortunately, GA
Thanks for your reply. Guess I need to start looking for another scanner. Thanks again.
Not neccessarily. Your county is still conventional. Not digital trunked. If you have no interest in listening to VA STARS, the digital trunked, which Franklin County is not a part of, your 210 will still receive the two narrow banded frequencies. It just won't be as loud. If, however, you wish to upgrade to a scanner that does the narrow band frequencies, RS has the Pro-163/164 refurbished scanners for under $100. New for $180. Just thought I'd throw in my two cents worth which can save you some money:)
HTH,
Larry
Ferrum, Virginia
Reply
Thanks for the info on the RS refurbished scanner. Most have been out of my price range but this may be something I can afford. Again thanks a lot. There is more to scanners than I thought but this is a great site for learning. That to all ya'll out there for the great information you have provided.
