Need some quick help with an XTS3000R
kd7nmn
I picked up a XTS 3000R last night and need some help. I programmed in a couple local amateur repeaters but the audio coming out of the repeater sounds horrible. However if I transmit in simplex it sounds just fine. What if anything needs to be done to the TX options? Right now I have the following
Transmit Deviatio: 5 kHz
Transmit Deviation T/A: 5 kHz
Channel Spacing: 25 kHz
TX Voice / Signal Type: non-Astro
Transmit Emphasis: Checked
Reverse Burst / Turn-Off Code: Checked
C
comsec1
Guest
I hat to say it but its probably the reason someone was getting rid of it.
kd7nmn
If that were the case wouldn't simplex sound bad also?
--Scott
43g70
What do other user on the repeater sound like?
It could be a crappy repeater.
mm
Open Astro XTS3000 CPS and expand on the RADIO CONFIGURATION menu and click on the RADIO WIDE menu pull down list then look for AUDIO GAIN OPTIONS and see if ANALOG is checked. If so uncheck it, this may or may not be your problem.
If it is not checked then I'd suspect that your radios RF board may have been changed out and not properly aligned and this sounds more like your problem.
The repeaters IF bandwidth is probably tighter than the IF bandwidth of the radio that you are using to listen to in talkaround mode.
Or the repeater could also be passing thru CTCSS tones which if they are excessively high will cause distortion on the repeated audio.
You will need to use ASTRO RADIO Tuner and go into the TRANSMITTER ALIGNMENTS and look for TRANSMITTER DEVIATION LIMIT, you will need to click on help the see the correct alignment procedure.
Another thing which may cause the problem is the TX DEVIATION BALANCE being misaligned, this is also is in the same Astro TUNER TX alignment menu.
If the low frequency compensation is set to high then CTCSS tone deviation will be excessive causing audible hum in the TX as mentioned above.
The excessive CTCSS Deviation may come across higher than normal when transmitting thru the repeater, especially if the repeater is not balanced correctly between RX and TX.
While in Tuner also check the REFERENCE OSCILLATOR and make sure it is set on frequency.
Either way if you go into TUNER you will need some way to measure CTCSS tone and TX audio deviation along with the tx frequency.
Mike
kd7nmn
I appreciate the input. I did some more playing around and it sounds fine. Not sure if I was getting external interference or what the deal is. I've now used it a few times with great reports.
Scott
fineshot1
NJ USA (Republic of NJ)
Scott
Scott - not sure what your using to measure the deviation. I always set mine up for about 4.4 - 4-6Khz with PL Tone(about 500-600Hz). This should be plenty for any commercial or amateur repeater. Anytime I have ever had a problem with deviation through a repeater and it sounds fine on simplex its always a but too high for the repeater in question(some seem to be a bit more sensative than others). It may be usable if you keep backed off the mic.....
