Need some sports help
raymondjtoth
des plaines il
Hi i know indy 500 comming up since no people are going to be there can we use a scanner to hear the freq thay use im in desplaines Illinois usa was woundering if so what do thay use? Wasnt sure if that opened it up to home user in home yet
This post should be in the sports forum, not general scanning. That said, they use simplex radios for most of the comms and unless you are at the track or in the parking lot it is very doubtful you will hear the cars. Also, the officials use DMR which your scanner can not pick up. Frequencies for drivers and track can be found in the forums and wiki. Ray, you should learn to use the search feature at the top right of the page and you will find most of the answers to your questions.
