Need to id this resistor on this amp
NITROTURBO4U
NORTH EASTERN SOUTH CAROLINA
This is a palomar tx-200...The resistor in photo is attached to the high low switch.
anyone familiar with this amp..???Thanks all
jonwienke
More Info Coming Soon!
VA
The color code is burned off, so you'll need to find a schematic.
com501
A competent radio tech woould be able to approximate the required value from examining the circuit. I doubt that a schematic is available anymore for those amps.
You should also determine what overdrive condition caused the failure before you replace the component.
