Need to Identify Antenna Connector
SolarPV
I need help to identify the following non-standard connector that is used to plug in a cable linking to a standard SMA-type Wi-Fi Antenna.
The connector I need to identify and purchase looks like this:
It plugs in to this receiving pin:
I tried to take measurements as best as possible,
- The connector outer diameter is approx. 6.3 mm
- The receiver outer diameter is approx. 4.4 mm, inner diameter 2 mm, and signal pin 1 mm
Can anyone identify this model of connector and suggest a vendor to purchase from?
Thanks in advance!!
G7RUX
That is indeed a MCX connector and is avaiolable from many places as it's a pretty standard equipment connector.
