- Joined
- Jul 22, 2020
- Messages
- 3
Where can I send my trx1 for MARCS and P25 programming ?
MARCS is P25. What is your city and county?Where can I send my trx1 for MARCS and P25 programming ?
Good morning and thank you for your interest. Mentor Ohio and Lake county. Scanner was working well , I decided to dig into menu ,wrong move, scanner reads “nothing to scan.”. Opened laptop to download info from whistler software and message reads “ Ed card does not appear to be properly formatted for use with your scanner. Copying data to this card may cause your scanner to operate incorrectly or not at all.” Promise to leave menu alone if corrected. Thank you!MARCS is P25. What is your city and county?
And get a spare card. They do go bad occasionally.Under the Scanner/SD Card tab, Prepare Scanner Memory/SD Card for Use.
I used Zip Scanners when I purchased my TRX-1, contact them and they can program and send you a card with what you want on it. They have amazing customer service too!! Then I finally figured out Not so EZ Scan took me a while but do have it figured out. Was so used to ARC 95, EZ Scan was like learning a new language! Definetly back up what you use though! Get a few cards and keep them in a safe place if the card you are using in your scanner goes bad!!Where can I send my trx1 for MARCS and P25 programming ?
