'Negative squelch' software
Cuatro
Hi all,
I have recently picked up some broadcasts on the low end of the FM spectrum and rather than sit at my PC all day listening to a few clean signals between mostly noisy static i was hoping to record them.
The issue is, given that it's FM, the actual broadcasts are much quieter than the static, and as a result, any VOX/Squelch software i try, made to filter out weaker signals, just records this louder noise.
Does anyone know of any software/way i can record only BELOW a certain volume threshold?
Thank you
zz0468
Banned
I know of no software that will do what you're asking, but an easy fix could be had in hardware, if you're able to fabricate simple circuits. You could build a simple VOX circuit, adjusted to respond to the static, and invert the switched output so that it mutes the static, but not the program audio. It would function as a squelch, of sorts. Better still would be to modify the receiver and put in a real noise squelch.
I presume it's real broadcast FM... is it stereo? Use the 19 KHz stereo pilot signal, which usually drives a "stereo" indicator light to switch your audio. The drawback to that is that it would be non-responsive to a mono broadcast. But it would be cheap and easy.
Cuatro
Hey, thanks for the reply.
Hmm, I don't think i can be bothered making any hardware for this, it's not that important, i was just hoping someone knew of a simple program that say, had a volume filter which allowed recording only between certain levels.
I imagine my 'setup' is very different to most here. These broadcasts are at about 76MHz, and i pick them up on my tv/fm tuner card in my PC. Nice idea about the stereo pilot signal, but in any case i think these transmissions are mono...
Never mind, and thanks anyway.
Shortwavewave
I have a small mp3 player that has an FM radio that has a 'japan' setting for the broadcast and somewhere in the 76mhz is a local tv stations for me.
Cuatro
Haha, for me they are slightly more interesting. They are police/fire comms transmissions.
