Nevada County 10-codes ???
G3MiNi
Usa
Anyone know where I can find the 10-codes for Nevada County CA (which includes services like Nevada County Sherrif and Grass Vally PD)?
Thanks!
G3MiNi
Usa
Thanks DDan. I've been to that page before and never bothered to click on that link ... duh.
KMA367
Redwood Coast, N Calif
This looks like a good starting point. Click on the "radio codes" button on the left.
http://www.spiral.com/nevada_county_scanner.php#
Granted it was 20+ years ago, but when I dispatched for GVPD we and NCSO didn't use the vast majority of the 10-codes on that list, but only the more common ones -
10-1 - Receiving Poorly
10-2 - Receiving Well
10-3 - Switch to Channel __ (or to "scramble" - simple voice inversion stuff back then)
10-4 - Understand
10-6 - Busy
10-7 - Out of service
10-8 - Available
10-9 - Repeat
10-12 - Are you clear to copy (warrant) information?
10-15 - In custody, off to jail
10-18 - Fueling patrol unit (GVPD anyway)
10-19 - At (or Go to) Station
10-20 - Location
10-21 - Phone
10-22 - Cancel
10-23 - Stand By
10-28 - Veh Registration
10-29 - Check for Wants
10-33 - Burglar Alarm
10-42 - Out at home
10-47 - Prepare to copy a call (GVPD)
10-48 - Go ahead with the call "
and 10-97, -98, -99 common Calif meanings​
We also used the CHP's 11-79 thru 11-83 for traffic collisions, and 11-95 for "Making a traffic stop"
NCSO has a different unit numbering system from back then, but Nevada City PD and Grass Valley's seem to be the same. At the time GV didn't have any ranks above Sergeant ("37-xx") other than the Chief ("35"). They were just about to create a Lt position, which went to Sgt Johnson, but no Captain position existed for several more years.
For patrol officers, their unit numbers were semi-permanently assigned, based on seniority in the position: 38-1 being the most senior patrolman, 38-2 the next, then 38-3, 38-4 etc. Sergeants were the same, with 37-1 being the most senior Sgt, then 37-2, etc. Whenever someone left the department (which was real common at the time) everyone below them had their number moved up a notch.
G3MiNi
Usa
hmarnell ~ great info ... Thanks You! I have noticed that from the rather large list of 10-codes that GVPD and NCSO still only use a handful of them on a regular basis, like you pointed out.
