Nevada Shared system
K9DUO
Norfolk, Va
Im visiting Las Vegas for the week and programmed my Pro 197 for the Nevada system so I could monitor the highway patrol while Im here. However Im not getting anything. I programmed all the area control channels and set the program for EDACS standard. Im getting a good signal on the S meter, but no trunking indication. Anything I may be doing wrong or some secret to getting their system programmed?
hotshotmike1001
Mohave County, Arizona
hello K9DuO the trunking systems here in las vegas are Messed up You need to make sure you tell the
EDACS standard its rebanded for it to work i get best Sig from North las Vegas Site I Cannot get the shared radio system working at all so hopfully that helps you
KF7RAY
Reno,NV
Make sure you program ALL the frequencies for each site in the order they are listed. EDACS requires all the frequencies unlike some other systems.
3mary2
Las Vegas, NV
I have found the Rio Hotel frequencies to give the best enjoyment for the strip area. You are only loading one site into each bank/folder and using all the frequencies as they are listed in the database? I listen to the Rio site from my home in the northwest part of the valley to work at Russell Rd and I-15.
K9DUO
Norfolk, Va
Havent done this. I dont have any EDACS systems back home (thank goodness) so Im probably not programming it right. I know its different then Motorola systems. Can you give me some more details?
Also Im using Win500 to program a Radio Shack Pro107
thanks
3mary2
Las Vegas, NV
Using the Win500 program, go to the database and download the Rio site only. The frequencies have already been changed to show the re-banding. Talk groups to use should be LV-1,2,3, with Tacs and Car to Car 1,2,3. This should automatically set the system up for you. Hope this helps you.
K9DUO
Norfolk, Va
I have to manually enter them as im not a premium subscriber....do the freqs have to be entered in numerical order from lowest to highest or in the order they are listed here on Radio References database?
