New 700 System A4E
scanlist
Scanning since the 70's to today.
Greeley, CO
Discovered this system while band serching. Recievable In Boulder County and fair in Weld County.
The call signs broadcast on the CC do not exist per the ULS.
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : A4E
System Name :
WACN : BEE00
Tower Number (Decimal): 1-1
Tower Number (Hex) : T0101
Tower Description :
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) : KID388 KID391
Timestamp : Wed Apr 3 17:01:55 2019
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,935.01250,0.01250,-39.00000,"Confirmed",0.01250,1
05,935.01250,0.01250,-39.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"01-1316","ci",770.23125,"01-1316",800.23125,0,3
"01-1356","a",770.48125,"01-1356",800.48125,0,0
"01-1396","a",770.73125,"01-1396",800.73125,0,0
"01-1436","i",770.98125,"01-1436",800.98125,0,2
"03-1397","v",770.73125/1,"03-1397",800.73125/1,1,1
Spitfire8520
I might be completely clueless! =)
Colorado
What range of talkgroups are you seeing? It could be the Site on Wheels since the State is the only one that can legally operate with their blanket 700 MHz license. I believe whatever is in the database has been outdated for a bit.
ScannerSK
Weld County, Colorado
I'm monitoring this and not seeing any talkgroups. It could be in testing mode as the identifier KID388 is continuously being sent out around 3 times each minute. As the callsign is not in the FCC records, this would lead me to believe this could be some type of federal system.
Shawn
greenthumb
Colorado DB Administrator
Any chance this is strongest near the NOAA/NIST campus in Boulder?
