rumcajs_tr
No need for emails... I am selling this receiver... It was big mistake to buy it.
For me, AIS works very well with the original antenna.I have not been able to decode AIS transmissions with the DJ-X100T with firmware version 4.00-003. I have done significant troubleshooting with Alinco support with no success. I have tried this using 2 brand new radios at locations in 3 different states. I entered the AIS frequencies and mode using the Quick Key 5, memory channels, and manual entry in VFO mode. I have used both the radio GPS position and a manually entered FIX. Neither the radio position display nor the Alinco provided Position Viewer software display any AIS positions despite more than 100 hits on other AIS receivers. ALINCO Japan has yet to admit there is a problem despite my findings and information from my dealer that others have reported this issue.
Only once has my E version radio shown a ship on the screen and I have never been able to replicate it since.At least one poster here stated his does work with AIS. The ACARS works fine on my 100T. But no luck on getting the position screen display showing any locations. Maybe the E version works and the T doesn’t.
Same here, I've never gotten ACARS POS data to show on the map and I have the T model tooAt least one poster here stated his does work with AIS. The ACARS works fine on my 100T. But no luck on getting the position screen display showing any locations. Maybe the E version works and the T doesn’t.
Mine receives and decodes the data just fine, it won’t show the position on the display.The X100T certainly should receive and decode ACARS messages, provided it is correctly tuned, SNR is sufficient and a compliant ACARS signal is being received.
I would like to get a X100 on my bench so I can check out the performance of a real unit...I'm quite keen to move on my R30 to get one.
It might be worth using the BlackCat ACARS decoder and feeding it with audio from the receiver to be sure it's a good ACARS signal you are receiving and this might allow you to pin it down to the decoder in the X100.
ACARS doesn't contain GPS info (typically), so its not going to show up on the display. The manual says that if the receiving signal contains GPS information it will display it. I can decode ACARS without any issue here(both J and E versions). I have no way to test AIS in Colorado
Anyone have a copy of the firmware updater for V3.90 which was the original firmware the T and E were shipped with?
alinco.com
They only have the latest update, not the original that was shipped with the radios which was 3.90. I was looking for it because they removed POCSAG in 4.0 but it appears you can still unhide POCSAG in V4.0
Hi all, newbie here! Been here a while but never really posted, I mostly just use for research but I need to be active. So I'll start with this - recently got a X100e and was wondering if anyone misses any channels when scanning? I'm connected to a Diamond X-50 roof mounted which is pretty strong, so I need 20ATT to reduce any overload. But I do find I miss TX on some weaker channels due to this. Any suggestions please?
To be honest it looks like a good fit for amateur radio in that it covers the main DV modes and covers 2/70, plus a bit so it will probably sell reasonably if it's not too expensive.
