New and Need Help
mpolnika
I am having a hard time understanding what information is important in the RadioReference database. I want to monitor fire and police on seperate scanners. To set up a scanner to monitor fires only what do I need to know and what do I need to program?
unitcharlie
a Kentucky DB Admin...
far from Nonesuch, Ky...
welcome to the crowd....
give us a little more info... where you live , etc... if you have scanners, which ones and if you the price range you are willing to invest.... plenty of help in here.
mpolnika
I have already invested thousands in the scanners, Uniden BC796D, discone and beam antennas, mast, cabels, etc. etc. The only thing I have left to do is program the scanners and make sure my antennas are picking up the signals.
Dubbin
Findlay Ohio
If you let us know where you are from then we can look at the system in the database and help you a little more.
mpolnika
I'm in between D.C and Baltimore and will monitor both areas.
mpolnika
Here is where I am really lost with the info on the database.
DEC HEX Mode Display Description
656 029 A MOSCAD (Station Alerting Data)
17616 44d D 4A/4P FDISP Dispatch
17648 44f D 4B RESP Response
17680 451 D 4C INC1 Incident 1
17712 453 D 4D INC2 Incident 2
17744 455 D 4E INC3 Incident 3
17776 457 4F INC4 Incident 4
17808 459 4G INC5 Incident 5
17840 45b 4H INC6 Incident 6
Which of this is necessary in programing the readios?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Which of this is necessary in programing the radios?
The DEC numbers are the key numbers here. Those 17xxx
numbers are what you want to program in your scan list.
You can alpha tag them with their descriptors as well so you can see
what is active at a glance.
Are you monitoring Baltimore County ? Make sure you have it trunk
programmed in MOT II mode.
Good luck.
mpolnika
"The DEC numbers are the key numbers here. Those 17xxx
programmed in MOT II mode."
OK, so I am using Butel software and it's self explanitory where the frequencies go but where do you put the DEC numbers? The books and manuals are not very helpful or I am real dense, maybe a little of both!!!
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Code:
DEC Description
17616  FDISP Dispatch
17648  Response
17680  Incident 1
17712  Incident 2
17744  Incident 3
17776  Incident 4
17808  Incident 5
17840  Incident 6
In ARC click on ID List from the Trunk menu. The numbers go in the left column and tags in the right.
