I recently started getting into this a hobby. Just to listen to local Fire,EMS and Police. I live in Franklin County PA, I was able to pick up a BC72XLT at a yard sale the other day for 25 dollars. I programmed all the frequencies that I found here
https://www.radioreference.com/apps/db/?ctid=2268 But the only thing I get is Fire and EMS. I assume I need a Digital scanner to hear my local Police can someone please confirm and let me know if this is correct and if so will the BCD436HP be a good scanner to get.
The BCD436HP is a good scanner. I have two of them.
However, for your county's system, I see that it is simulcast. Here's the map of sites:
Simulcast sites can be challenging to monitor, because sometimes, they cause distortion. See this Wiki article for more information:
https://wiki.radioreference.com/index.php/Simulcast_digital_distortion
That distortion, however, varies greatly upon your location relative to the sites. You may encounter zero problems, or serious ones. Sometimes, simply relocating your scanner even as little as a few feet can make a tremendous difference. At other times, you might need to use a directional antenna to receive the system.
As w2lie noted, someone in your local Pennsylvania area may be able to provide more information as to whether the system can be monitored successfully with a 436HP, or do you need to seriously consider either the SDS100, or one of the Unication pagers. If you'd like to have your thread moved to the state forum, do
not create a new thread. Instead, click on the Report in the lower left corner of one of your posts, and request that a moderator move your thread to the state forum. Someone in the area would be more likely to see it there. Be sure and specify what area of the county you are in, or the name of the nearest town or community.
