I will aslo say the ST2 would not have lived through the shipping disaster that this antenna went through.
Interesting, I had 2 of the ST-2's come in the mail to me, and neither were damaged. None of the DPD antennas I have were damaged.
I guess that the original ST2 designed had to be changed, as the balun are attached in parallell to the front elements and then the transmission line goes to the lower frequency elements and then the transmission line continues along the boom and ends up.... nowhere. The most logical would be that the balun where attached to the open non terminated transmission line closest to the mast pole. But something probably didn't worked as expected, 700-900Mhz signal maybe too poor, and the balun had to be moved to the front in a very awkvard and unnatural position.
/Ubbe
A discone is -zero- gain, and a completely different antenna altogether, not really a fair comparison.
The elements lenghts seem to correspond well with the frequencies but LO-VHF are a bit shortened, probably from the impact of other elements and also to raise the impedance. The front elements are 400MHz and 500Mhz lenghts but the 700-900MHz elements are a guess, perhaps the "leaves" work at that band or the 400-500MHz dipole work as full wave dipoles. But any metal object this big will receive any frequency.
/Ubbe
/Ubbe
It is actually only a couple of the elements that are active at a given frequency. It is the wavelenght from where the the coax connects that determine where a frequency will work along the boom. The longer from the coax point the longer the wave are, and a lower frequency, and the elements lenghts increase to match the frequency. The greater the frequency span of an LP antenna the fewer elements are active for a frequency and then it has less gain and less directivity.I have the DPD 118-1000 MHz Yagi antenna. I never owned the OmniX, but the LP antenna has been a great performer and has many elements for gain.
Initally I thought the same but it's measurements match to a 1/2 wave dipole for 420MHz and 500MHz respectivly and there's really no other elements that looks to be made for two bands in high UHF.I think the front small elements are 800/900MHz and probably longer than 1/2 wavelength overall giving the illusion they are 400-500Mhz.
That could be the case, but it doesn't explain the nonused transmission line and I beleive it's the reason for having the balun at the front, it didn't work having it at the other end due to the mismatch of wavelenghts. I guess that there where no professor in physics and antenna theory that design the antenna. It's just a bunch of elements for different frequency bands connected together and having as many elements as possible will make it pick up signals at most frequenceis, that are not too far from the levels what a single tuned dipole can generate, or a mistuned offset dipole.I suspect the placement of the feedpoint is similar to a log periodic where it always connects to the high frequency end of the transmission line that runs the full length of the log antenna.
Are you able to provide a design that would at least match and then exceed the noted coverage and performance of this passive antenna? I would definitely like to see your design. That would be fantastic. I'm not expecting a prototype, just a design with measurements. Start a thread and post the details please. Thank you.I guess that there where no professor in physics and antenna theory that design the antenna.
/Ubbe
The Omni X is 118-137 MHz, 148-175 MHz and 225-900 MHz
The ST2 is 30-54 MHz, 108-174 MHz, 450-470 MHz, 470-512 MHz, and 800-912 MHz
I do not see a similar antenna here.
Actually, no. Antennas only care about frequency, not how the frequency is modulated or data is encoded.Being an Omni X owner and having owned the ST2 I can tell you the Omni X is far superior in the 700/800 Mhz range and on digital traffic.
