Antennas made it to the tester today, I guess the Special Handling stickers I put on the boxes din't help.
No i did not add woodDid the ST2 ship with a 3' piece of wood in the box? Some antenna I purchased shipped with a .5" x 1.5" piece of cut wood in the box.
Yeah, That's special handling all right.It looks like the one got special handling...
....... otherwise I will have to TRY and buy one
from all these people that have them stored.
You don't have one that you are comparing it to?
I'll let you test mine (NOS, in box) if you will return it to me, -and- send me one of your antennas when they are done. I like to try things out, heck it may work out good
I have searched hi and low for this type of antenna mast clamp, I have googled everything I could think of and the only place I can find this type of clamp is in a Hardware Kit from channelmaster. I want to buy just the clamp, if you know where to buy Just the clamp(u-bolt and the two piece clamp) please post a link.
Seen it but won't work not the same it needs that rear piece of clamp to go over the square mast of the antenna, ThanksHere's a similar clamp.
Channel Master Universal U-Bolt and Nest Assembly CM-9017 - The Home Depot
Channel Master CM 9017 U-Bolt and Nest Assembly is used to secure a TV antenna to a mast up to 1.5" in diameter. Made of high quality components. Easy to use.www.homedepot.com
Robert
No, see the red arrow, this has to be part of the clamp.All are very similar
Mounting Hardware U Bolts Lag Stake Plate
Mounting Hardware U Bolts Lag Stake Platewww.summitsource.com
There are others - Google
U-Bolt and Nest
Looks like a Channel Master 9017
I believe that is the clamp that came with the ST2 scanner antenna, or scantenna.
