I believe that is the clamp that came with the ST2 scanner antenna, or scantenna.
Heavy Duty Medium Mast Clamp and Round U Bolt | 3 Star Incorporated
Might work
You are correctI believe that is the clamp that came with the ST2 scanner antenna, or scantenna.
Yes I stated that in post #134 that I found it there, but I don't want the whole hardware kit just the clamp and they don't sell just the clamp.
Yep I seen this one as well, but not the same it won't fit around the mast/boom tube.
I already was aware of this link, so I checked it again just in case I missed something. The replacement parts listed in this link will Not work for my antenna. I checked the antennas that these repair kits were for CM2016, CM2018 & CM3016 and all of these antenna have a round Boom/Mast tube as the main tube, which means the clamp is for a round Boom/Mast type antenna, mine is 1" square Boom/Mast tube.Check this ink, there are multiple clamps.
Replacement Parts
Looking for Channel Master replacement parts? Here is a list of all available replacement parts available for purchase from Channel Master.www.channelmaster.com
After reconsidering the distance from the long center radials to the mast in reference to the original mast/boom length of 20", I have decided to make this mast/boom longer. To open up this gap. Figuring 1" of the mast/boom through the mast clamp and 1 3/4" from to the center of the mast clamp is where your mast pipe would end up being. That would give you a distance of 11" from the center of your mast pipe to the back of the long radial and that would be the distance that everyone was concerned about, was never a problem before but... I can make that a bigger gap by making the mast/boom tube longer on the antenna (as pointed out previously).
With the new length of 26" mast/boom tube the distance that was 11" now becomes 17" gap between your mast pipe and the long radial.
I am more then confident that the heavy duty mounting clamp that is included with this antenna can handle the additional weight hanging out 6" more then before.
So see....... I do take into consideration your thoughtsCan't and won't always comply with them but in this case I did.
If for some reason you don't think the clamp can handle the additional weight and still keep the antenna horizontal, then just slide the mast/boom tube further through the clamp.
Here is a small drawing showing the dimensional aspects. The Numbers in the Green Boxes show the distance change that is the topic of this thread. "A" showing how the original was spaced and "B" showing the New Spacing. Not shown, but the long center radial is in the center of the center insulator.
I would be very interested in what you think they should cost, I asked way back in this thread for opinions on cost and not one person mentioned a price, so please let us all know what your price for this antenna would be?189 plus shipping ouch...I paid 35 in 2010 for my st2. I get they are hand made but still..
No I am not pulling a price out of the air.There were, but were removed by a mod as "off topic". So are you just pulling out a price from the air?
Out of my price range, glad I have a few original ones.
Good luck!
