I tried to post a reply to some questions about my home made mast poles last night and something was wrong with the forum I guess. I could never get it to post. So....I'll try to explain this again! It is really stupid simple. I'm just the kind of person that will try and build something rather than buying it if possible. I even enjoy building my own antennas very much. Anyway....I buy 10' sections of galvanized metal conduit pipe from the Lowes near my house. I would have to go outside and measure to be exact. But, what I'll do is buy, let's say, a 10' section that is 2" in diameter, another that is 1.75" diameter, another 1.5", etc. You get the picture. I will in order of descending diameter slide one pipe into the other. But, only far enough into the larger diameter pipe to insure that this joint area will NOT be a weak point. I then cross drill through the two sections and bolt them together with bolts, nuts and washers of course. Once the mast is put together, then comes the part that supports it. Also the part that some people may not want to do.....but it works! I will take a post hole digger and dig a very nice clean hole and place a 4X4 wooden post in it. I'll get it perfectly straight and level and then mix and pour Qick-Crete in the hole. Thus cementing the 4x4 in the ground. I'll leave maybe 5-6 feet above ground. Once that is dried I place the base of the mast that I built against the base of the 4x4 and slowly walk the mast up. Once its erected and against the support post, I actually will fasten it to the post with three ratchet straps good and tight. The straps being well spaced from the bottom to the top of the post. I live in Alabama and we regularly have severe thunder storms with high wind and worse. I have had these masts up with antennas on them for years and they sway to and fro.....but never have they ever bent or broken from wind. Now keep in mind. They are not suitable for large antennas with weight or high wind load. I have used them without incident with verticals, small loops, ridged dipoles and supports for large HF dipoles that stretch quite far across my yard. The actual height that I normally get out of these is usually just shy of the 40' mark. They are closer to 35ish' (give or take) once said and done......this I have found to work the best. Any longer and there may be issues where the sheer weight of the mast could bend while erecting it. But it's a simple way to get an antenna up at a descent height
without having guy wires stretched all over the place!! And it is VERY durable!!!
I'm gonna try and post a couple of pics......if I can!
Above is a 6 meter loop on one of the masts. This one is right around 36-37'.
Same 6 meter loop. If you look close you can see where I bolted sections together.
Above is not the greatest pic. But, it is a center support for a 40 and 20 meter parallel (fan) dipole. This is where the balun hangs. The antenna is not up here, I had it down for a bit of maintenance I believe. This whole antenna system is on pulleys so that I can raise and lower easily. You can see the top of the 4x4.
I hope this helps explain......nothing elaborate! But it does the job quite well!!
I hope to eventually get my new Diamond discone antenna up on one of these and get my BCD996XT hooked to it!!
Thanks a bunch fellas!
