Element lengths? WTF is that? I just want a giant piece of metal to plug into my scanner that doesnt cost much and requires little effort to put up, thus the TV antenna idea: it is already mine, and it is already up.
Now about the range, when you say "short range" exactly how short? If it wont extend beyond my block, then it isnt worth it. Naturally I am assuming it is better than the little 6 inch antenna that came with the scanner. Its actually a portable, but while at home, why not "convert" it to a base scanner instead of carrying it around everywhere?
Back to that elements thing, you say they are no where near the same except in 800 MHz. Perfect. That is all I am interested in.
On to the polarization, you say that almost all "scanner type freqs" are vertical polarized. Which ones arent? If the 800's aren't then great!!
Aside from the 800's there is only one other frequency that I listen to regularly and that is 453.875. The only thing is that happens to be the one that is transmitted from farthest away. I have to go about 3 miles south before I get really good reception with my 6" standard antenna.
As for the "fancy language" and "highly technical words" thanks for assuming I had the slightest idea what you're talking about despite my asking about plugging a TV antenna (I have no idea what kind, but its on the roof) into my scanner.
You guys rule!!
