B
BNN987
Guest
Hey guys im looking to buy a new antenna, i know what kind of outdoor antenna i want but im wondering exactly what i need to install it and place it on a outdoor chimeny. i am getting it professionaly installed and i need to know what else i need, so far the antenna i have has the following specs Special Features:
• Ultra-wideband design 25 to 1300 MHz receive, 50-1300 MHz transmit (6m tunable for transmit)
• Compact and lightweight design enables antenna to be installed on balcony railing at an apartment or condominium
• Ideal for 2m, 1-1/4m, 70cm, 33cm and 23cm amateur bands
• Excellent "shop" antenna for testing various transmitters on a single coax
• Can be made further compact and lightweight by removing the top loading coil if 25-50 MHz reception is not required
Specifications:
Bands:25-1300 MHz
Gain dBi:2 (nominal)
Max Power Rating:144 MHz up: 200 watts 6m: 20 watts FM, 50 watts PEP
Height:5.6'
Weight:2.2 Lbs.
Connector:UHF
Element Phasing:Wideband Discone
Specifications:
Bands:25-1300 MHz
Height:5.6'
Weight:2.2 Lbs.
Connector:UHF
