n3vbj
Pro 106 VR adjustment
This is unnecessary! Baltimore county's New System is vulnerable to multi-path signals. Its DIGITAL which is a data stream of 9600 Baud data. If you use a Super-duper antenna and can't understand why your digital audio is garbled you get the signal from Multiple paths and when your scanners DSP try to decode a broken data stream it sounds like its underwater. Ever since the test of the system in February I have used 1 inch stubby antennas and have had no problems with garbled signals. Unhook the super 800Mhz whips and discone outdoor high gain antennas and use a stubby antenna like they sell on E-bay and other sites and your headache will be solved!!!!! Once you get the Stubby rubber duck and compare it to your High Gain Super duper scanner antenna the difference with the Stubby is night and day. Stubby full strength signal and perfect audio..........High gain antenna...... Fluctuation in signal strength and garbled audio it's not hard to figure it out.
All of the users on Radio Reference Forum's will tell me I'm crazy and have no idea what i'm talking about but it's simple.... 1 inch stubby duck I have no dropout or garbled decoding. Next time you see a Baltimore County Police officer or Fire Department employee look at the Walkie-Talkie's they have. The Police officer's have a 1 inch stubby antenna mounted on top of the Speaker/Mic on his chest. The fire fighters Motorola units all have stubby's. Duh put one on your digital scanner and you can hear with no problem!!!
This will also work for Home Patrol and Uniden/Bearcat and most Digital scanners.. You may require and adapter or order the Stubby with right connection for your scanner IE BNC or SMA
